checkbox field on member list [object Object]
spadco
Beitrag von spadco »
added checkbox field on
https://~/manager/adm_program/modules/members/members.php displays only as
[object Object]
but it displays correctly as a checkbox on other lists eg
https://~/manager/adm_program/modules/groups-roles/lists_show.php?rol_ids=2
Bug?
Re: checkbox field on member list [object Object]
So you have the current Version 4.3.8?
This should be fixed there.
spadco
4.2.14-2
Installed via cPanel Installatron:
"The web application selected is already running the latest version."
I guess I'd better ask my hosting provider to update their Installatron.
I could follow https://www.admidio.de/dokuwiki/doku.ph ... 2.0:update
But ponly now do I discover inside cPanel via Softaculous it's 4.3.8 :shock:
Oh well.... I have work to do....
spadco
I carefully followed https://www.admidio.de/dokuwiki/doku.ph ... 2.0:update and I'm now sucessfully running 4.3.8
However, Menus move up/down is broken - displays popup text box with some page's code with
<title>sitename - note</title>
