iCal generated with error
Prim0
Beitrag von Prim0 »
Hi
I cant import iCal files generated by admidio to any calendar.
The problem is with LAST-MODIFIED: line, it is null
After edit it in notepad and add missing date it works correct.
I need to know that there is any way to resolve it ?
Best Regards
Re: iCal generated with error
Thanks for the hint. This will be fixed with the next release.
https://github.com/Admidio/admidio/issues/1479
