Contribution - decimal
jhoulston
Beitrag von jhoulston »
Is it possible to have a decimal charge for contribution?
Re: Contribution - decimal
If you have the membership fee plugin installed, you can enter decimal contributions via "Preferences-Advanced role editing". This is not possible directly via Admidio.
Oh, I didn't know, that this is not possible. Internally we store the value within a decimal database field.
I will change the UI, so that it is possible in future versions.
https://github.com/Admidio/admidio/issues/1408
