Client Browsers running out of memmory
darkoracle
Beitrag von darkoracle »
Hi
Hope someone could be of help, we are using admidio with around 10 000 members, and everything works well except when doing the following:
Groups and Rolls
Edit List
We select 21 fields to view
Role: Everyone
Display List
This causes an out-of-memory error on Chrome and Edge after about 30 seconds of loading, on Chrome I found a solution by adding the following:
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --max_old_space_size=4096
While this is a workaround having every member many not tech savvy at all having to implement it will be difficult, is there anything server-side or in the admidio software we can do to no.1 speed the process up a bit and no2. prevent the error message in the first place.
Any help will be appreciated.
All the best
J
darkoracle
Re: Client Browsers running out of memmory
No one have any idea :( ?
It looks like your query is to big :-/
Have you tried it with less fields. Maybe start with 2 fields and look if you got all 10000 Members and than expand the list with some more fields.
darkoracle
fasse hat geschrieben: 24. Sep 2022, 08:06 It looks like your query is to big :-/
Yes this works, however, they use this list for reports, any chance that a future version could have a workaround to this issue, I mean the company I work for's database has 15x the entries with easily 50x the fields and we access that from a web browser with no issue.
All the best and thanks for the hard work.
J
