passwords.txt - Can I remove it?
RVice
Beitrag von RVice »
My site was flagged by a scanner for abuse (phishing) on a webhost because passwords.txt was found.
/adm_program/libs/client/zxcvbn/data/passwords.txt
Is this file needed? Can I remove it? Does it prevent anything?
Re: passwords.txt - Can I remove it?
Hmm, no this file should not be removed. It belongs to the script which checks if the password is safety enough.
Hanabi
Beitrag von Hanabi »
Perhaps you have to change to https. Different scanner for "potential pishing" have a problem with http (unsecure).
Mit sportlichen Grüßen
Thomas
