Plugins
bryan
Plugins
Beitrag von bryan »
In Version 4.03 the Overview screen comes with a lot of the plug-ins visible and installed - there does not seem to be any place in Preferences to turn them OFF - we don't want Birthdays and looking for a way to disable it without going into the code too much - simply delete the plug-in? Its sample Config file doesn't seem to have an "enable" parm?
Thanks
Bryan
Re: Plugins
Hi Bryan,
I just added a short description how to modify the overview page:
https://www.admidio.org/dokuwiki/doku.p ... rview_page
