Error in Formfiller
yathish
Error in Formfiller
Beitrag von yathish »
Hi ,
i am the getting the error while using formfiller
Admidio version 3.3.17
Plug-in name: Form filler
Version 2.3.6
Status 10.01.2020
Last step of update 740 / 740
PHP version 7.3.11
MySQL-Version 8.0.18
i am tried downgrading the plugin...
Can help me to fix this
Error PDF.jpg (57.56 KiB) 7641 mal betrachtet
regards,
yathish
yathish
Re: Error in Formfiller
yathish hat geschrieben:Hi ,
Version 2.3.6
Status 10.01.2020
PHP version 7.3.11
regards,
yathish
Hi... I am still waiting for a resolution
Sent from my RMX1851 using Tapatalk
Hello yathish,
from which Formfiller version to which Formfiller version did you downgrade?
yathish
Hello sir...
I installed formfiller 2.3.7 initially and faced the same issue and downgraded to 2.3.6 and same issue. I downloaded both from GitHub.
Kindly note I m using ampps latest version.
Thank you
Hello,
this error is not caused by the downgrade. You can therefore also use Formfiller 2.3.7.
Please change lines 721 and 731 in creatpdf.php:
from
continue ;
to
continue 2;
yathish
Hello,
Sir thank you the Problem is solved now its fine....
Thank alot for the reply
Regards,
Yathish
