Update to 3.3.17 -
Mort
Update to 3.3.17 -
Beitrag von Mort »
Just installed this update on my installations, and now every time a change is saved for a user data or a profile field, instead of moving forward, it goes back, saying either the "field surname" or "category" is empty.
Have tried reinstalling, new installation has the same problem.
Anyone else see this?
Re: Update to 3.3.17 -
Could you reproduce this behavior on our Demo-Area?
Which version do you use before?
Mort
Beitrag von Mort »
I think I was using either 3.3.15 or 3.3.16 and just updated to 3.3.17 today, and did a new install. It may be something machine or install specific, as a trial install of 3.3.17 on XAMPPs is working properly. I just cannot find what I have done to change the other installations.
The demo is 3.3.15, and I cannot reproduce the problem there.
