Aufgetretene Fehler
dreael
Aufgetretene Fehler
Beitrag von dreael »
Während meines Tests sind folgende Fehlermeldungen aufgetreten:
/var/log/httpd/error_log hat geschrieben:[error] [client 192.0.2.53] PHP Fatal error: main() [<a href='function.require'>function.require</a>]: Failed opening required '/home/wwwroot/www.example.com/admidio-1.4.7/adm_config/config.php' (include_path='.:') in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... common.php on line 36, referer: http://www.example.com/admidio-1.4.7/ad ... /index.php
[error] [client 192.0.2.53] PHP Notice: Undefined index: address in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 146
[error] [client 192.0.2.53] PHP Notice: Undefined index: birthday in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 154
[error] [client 192.0.2.53] PHP Notice: Undefined index: city in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 148
[error] [client 192.0.2.53] PHP Notice: Undefined index: country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 149
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... zation.php on line 57, referer: http://www.example.com/admidio-1.4.7/ad ... /index.php
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... le_new.php on line 335, referer: http://www.example.com/admidio-1.4.7/ad ... rofile.php
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... le_new.php on line 335, referer: http://www.example.com/admidio-1.4.7/ad ... user_id=22
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... le_new.php on line 335, referer: http://www.example.com/admidio-1.4.7/ad ... user_id=33
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... le_new.php on line 341, referer: http://www.example.com/admidio-1.4.7/ad ... rofile.php
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... le_new.php on line 341, referer: http://www.example.com/admidio-1.4.7/ad ... user_id=22
[error] [client 192.0.2.53] PHP Notice: Undefined index: default_country in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... le_new.php on line 341, referer: http://www.example.com/admidio-1.4.7/ad ... user_id=33
[error] [client 192.0.2.53] PHP Notice: Undefined index: email in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 141
[error] [client 192.0.2.53] PHP Notice: Undefined index: fax in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 152
[error] [client 192.0.2.53] PHP Notice: Undefined index: first_name in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 137
[error] [client 192.0.2.53] PHP Notice: Undefined index: homepage in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 153
[error] [client 192.0.2.53] PHP Notice: Undefined index: last_name in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 136
[error] [client 192.0.2.53] PHP Notice: Undefined index: login_forward_url in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... _check.php on line 66, referer: http://www.example.com/admidio-1.4.7/ad ... /login.php
[error] [client 192.0.2.53] PHP Notice: Undefined index: mobile in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 151
[error] [client 192.0.2.53] PHP Notice: Undefined index: phone in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 150
[error] [client 192.0.2.53] PHP Notice: Undefined index: zip_code in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... e_save.php on line 147
[error] [client 192.0.2.53] PHP Warning: main() [<a href='function.main'>function.main</a>]: Unable to access /home/wwwroot/www.example.com/admidio-1.4.7/adm_config/config.php in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... common.php on line 36, referer: http://www.example.com/admidio-1.4.7/ad ... /index.php
[error] [client 192.0.2.53] PHP Warning: main(/home/wwwroot/www.example.com/admidio-1.4.7/adm_config/config.php) [<a href='function.main'>function.main</a>]: failed to open stream: No such file or directory in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... common.php on line 36, referer: http://www.example.com/admidio-1.4.7/ad ... /index.php
[error] [client 192.0.2.53] PHP Warning: move_uploaded_file() [<a href='function.move-uploaded-file'>function.move-uploaded-file</a>]: Unable to move '/home/phpuploadtmp/php1dIYoe' to '../../../adm_my_files/photos/22.jpg' in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... o_edit.php on line 284, referer: http://www.example.com/admidio-1.4.7/ad ... ?usr_id=22
[error] [client 192.0.2.53] PHP Warning: move_uploaded_file(../../../adm_my_files/photos/22.jpg) [<a href='function.move-uploaded-file'>function.move-uploaded-file</a>]: failed to open stream: Permission denied in /home/wwwroot/www.example.com/admidio-1.4.7/adm_progr ... o_edit.php on line 284, referer: http://www.example.com/admidio-1.4.7/ad ... ?usr_id=22
(konkrete Pfadnamen und IP-Adressen sind aus Sicherheitsgründen geändert)
Wichtig: PHP-Scripte sind unverändert verwendet worden. Verwendete Umgebung: SuSE Linux 9.3 mit Apache 2.0.53 und PHP 4.3.10 und MySQL 4.1.10a (wird aber demnächst aufs aktuelle 10.3 migriert) mit einer gehärteten php.ini-Konfiguration.
Ich gebe hier alles 1:1 weiter in der Hoffnung, dass die Entwickler den einen oder anderen Bug noch fixen können. Auf Wunsch wird von der php.ini gerne eine Kopie zur Verfügung gestellt.
Welche Einstellungen muss ich denn in der php.ini neben Error-Reporting: ALL setzen, um diese Warnings auch noch zu bekommen ? Bei mir werden die nicht angezeigt.
dreael
fasse hat geschrieben:Welche Einstellungen muss ich denn in der php.ini neben Error-Reporting: ALL setzen, um diese Warnings auch noch zu bekommen ?
Die relevanten Einstellungen:
error_reporting  =  E_ALL
; & ~E_NOTICE weglassen
Als verbesserte Sicherheit, damit der Webserver nicht jedem Angreifer die internen PHP-Scriptdetails in die Welt hinausplaudert:
display_errors = Off
log_errors = On
d.h. Fehlermeldungen werden dann schön brav in der beim Apache unter der in ErrorLog angegebebenen Datei ausgegebenen. => mit einem PuTTY auf den Webserver einloggen und während dem Testen immer ein
tail -f /var/log/httpd_error_log
laufen haben.
