Noticed [Deleted User(System)] with in room administration
amitabhmca
Beitrag von amitabhmca »
Dear All,
As in below screenshot, i noticed "Deleted User" Called system. However i have not deleted any system user. I have 2 admidio installations and all shows same.I clicked on "Deleted User" and it opens in user profile (see 2nd screenshot below)
[attachment=1]Deleted User in room administration.PNG[/attachment]
Deleted User - system profile... Only change i made it since installation was to remove administrator from membership role.thats it. Not sure if deleted user issue is due to that only..
[attachment=0]Deleted User profile.PNG[/attachment]
My doubt is that should i assign some role to this system user? or let it be the way it is or anything else am i suppose to do?
Thanks
Amitabh
Deleted User profile.PNG (54.38 KiB) 10523 mal betrachtet
Deleted User in room administration.PNG (27.31 KiB) 10523 mal betrachtet
Re: Noticed [Deleted User(System)] with in room administration
Thanks for the note.
This will also be fixed in 3.3.3.
https://github.com/Admidio/admidio/issues/760
amitabhmca
Thank you very much Fasse.
Regards,
Amitabh
