3.3 install failed
bryan
3.3 install failed
Beitrag von bryan »
Hi there - I attempted the upgrade to 3.3 from 3.2.14 and followed the instructions published - I did get the database conversion screen and a message that the database conversion was successful - however, as shown in the attachment, the install failed, since I get no user interface presented when I attempt to log in - I can log in successfully, but nothing is presented, other than a message confirming that I was able to log in - need to resolve this issue before attempting in the live system ..... Thanks!!!
Screenshot of Log In screen after upgrade to 3.3
Screenshot - Admidio Install.jpg (12.25 KiB) 13052 mal betrachtet
Re: 3.3 install failed
Have you also replaced the Plugin and theme folder?
bryan
Beitrag von bryan »
Hi there - yes, I copied the 3.3 Plug-in folder over the 3.2 one and I copied the 3.3 "Modern" Theme folder over the 3.2 one - however, the 3.2 instance in use uses another theme folder "Hiking" that I did not copy over
Thanks ... Bryan
bryan
Beitrag von bryan »
An update - I backed up my "Hiking" theme folder and copied "Modern" over it - the application now comes up OK, but without my "hiking" theme - so at this stage the upgrade is only partially successful
Thanks ... Bryan
You have to update your custom theme
https://www.admidio.org/dokuwiki/doku.p ... _themes_33
bryan
Beitrag von bryan »
Thanks - I must have missed the URL to the Theme Update instructions
Bryan
