[Plugin - Sidebar Online|Admidio-3.3.1] - Online sind text
amitabhmca
Beitrag von amitabhmca »
Hello All,
I setup Sidebar online plugin today and i see the text shows as " Online sind" as in below screenshot.
[attachment=0]sidebar-online.JPG[/attachment]
English translation file look like this -
<?xml version='1.0' encoding='UTF-8'?>
<resources>
  <string name="PLG_ONLINE_HEADLINE">Online</string>
  <string name="PLG_ONLINE_NO_VISITORS_ON_WEBSITE">No visitors are on the website..</string>
  <string name="PLG_ONLINE_VAR_NUM_VISITORS">#VAR1# Visitors</string>
</resources>
Can someone suggest what to be modified to fix that?
Re: [Plugin - Sidebar Online|Admidio-3.3.1] - Online sind text
could you delete your cookies and try it again
amitabhmca
Yes i cleared cookies in all browsers(Chrome/Firefox/IE/edge) & tried but it still shows same message with "Sind".
amitabhmca
Hello Ximex,
I was able to find out the line in Sidebar_online/config.php which says "Online sind" as below.. changed to "Online are" and its fine. may be correct this in upcoming version..
[code]// Text der über den angezeigten Benutzern steht (Default = "Online sind:<br />"
$plg_online_text = 'Online sind:<br />';[/code]
Thanks,
Amitabh
amitabhmca
I have another issue where i see all online users are also visible to visitors..how can i hide online users from visitors?
Your first problem is already fixed in the next version: https://github.com/Admidio/admidio/comm ... 5952369f80
Hi Amitabh,
both problems are fixed in Admidio 3.3.2 . We will release this version within the next days.
There you can configure if visitors could view member names.
Best regards
amitabhmca
Sure Fasse. thank you very much. I will try the new version.
Thanks,
Amitabh
