[Urgent Help]My admidio member website doesn't works after transition to HTTPS
amitabhmca
Beitrag von amitabhmca »
Dear All,
Today SSL certificate got installed and my admidio website(https://member.unihomeswelfaresociety.com) has gone bad.
myadmidio website with https gone bad-1.PNG (114.78 KiB) 25077 mal betrachtet
I have updated adm_program/installation/config.php as below: but still its not working.
// URL to this Admidio installation
// Example: 'https://www.admidio.org/example'
//$g_root_path = '%ROOT_PATH%';
$g_root_path = 'https://member.unihomeswelfaresociety.com';
Can someone help me real quick?
Thanks,
Amitabh
Re: [Urgent Help]My admidio member website doesn't works after transition to HTTPS
this is the wrong config file. The right config file is in adm_my_files/config.php
amitabhmca
Thank you very very much Ximex..Really appreciate your prompt reply..
I just corrected the line in adm_my_files/config.php & its working now. I will update the FAQ with this..
//$g_root_path = 'http://member.unihomeswelfaresociety.com';
Thanks again..
Amitabh
The config.php in the installation folder is the config template from that we create the config.php in the adm_my_folders. So please don't change the config in the installation folder
amitabhmca
Thanks for your suggestion Ximex..
I noticed that https lock/status on the browser for https://member.unihomeswelfaresociety.com/ doesn't seem to be stable.
How to make sure all member website content/pages loads with https. Any other file to be changed to https?
Loading mixed (insecure) display content “http://member.unihomeswelfaresociety.co ... s/home.png” on a secure page
Below screenshot is from developer panel (F12 in browser) and navigate to "Console", you will see the following warnings:
F12-developer console panel.PNG (14.72 KiB) 25064 mal betrachtet
As i see you changed the footer of admidio and added a link to the homepage. there you added the home icon with HTTP.
Use our constants to get the correct paths
https://www.admidio.org/dokuwiki/doku.p ... precations
https://www.admidio.org/dokuwiki/doku.p ... #constants
amitabhmca
Thanks for pointing out Ximex. Many thanks.
I have just corrected the link and all works fine..
Thanks for these links..
amitabhmca
Hi Ximex,
I want to add secure site seal code on member site.. any idea where should i copy this code..I tried in adm_program/index.php but i got white page..
https://www.positivessl.com/secure-site-seal.php
<a href="https://www.positivessl.com/trusted-ssl-site-seal.php" style="font-family: arial; font-size: 10px; color: #212121; text-decoration: none;"><img src="https://www.positivessl.com/images-new/ ... transp.png" alt="Trusted Site Seal" title="Trusted Site Seal for Transparent background" border="0" /></a>
<div style="font-family: arial;font-weight:bold;font-size:15px;color:#86BEE0;"><a href="https://www.positivessl.com" style="color:#86BEE0; text-decoration: none;">SSL Certificate</a></div>
If you want it on every site you have to put in in my_body_bottom.php in themes
amitabhmca
Many Thanks Ximex. I updated my_body_bottom.php and its showing in all the pages..
In case, want to display on home page only, which file to be updated to achieve this?
amitabhmca
Thanks a lot and appreciate Ximex.
I will update the FAQ => https://www.admidio.org/dokuwiki/doku.php?id=en:2.0:faq with this info.
