Removing Modules
fbonani
Removing Modules
Beitrag von fbonani »
I am trying to use Admidio to run a High School Alumni page but would not need or want a membership module. Is it possible to remove this module from the application?
Schwartz
Re: Removing Modules
Beitrag von Schwartz »
Hello fbonani
Look at this post : viewtopic.php?f=20&t=7697
And this : viewtopic.php?f=20&t=7798
fbonani
Schwartz hat geschrieben:Hello fbonani
Thanks for your reply. I was not able to find the screenshot material under the Membership Fee module unless I am missing it. I am using version 3.2.9 if that makes any difference. I would also want the Membership Fee information deleted from the registration form. Would eliminating it as per the forum post you suggest eliminate that?
if you have installed the membersfee plugin within your sidebar than there should also be a deinstallation button which should remove data of that plugin.
