Former Members
- photizosolutions
Former Members
Is there a way to disable the viewing of "Former Members" in the Lists?
Re: Former Members
Yes. Go into the settings of the lists. (Show former members)
- photizosolutions
Re: Former Members
Ok, I might be missing something here. I don't see it. Can i get a bit of hand-holding? Where is it?
Re: Former Members
Look at the attached screenshot.
The option "Show former members" (dropdown)
- Screenshot_20180307_092152.png (89.9 KiB) 18269 mal betrachtet
Re: Former Members
@photizosolutions: That feature is not implemented in the current version 3.2 of Admidio.
Ximex screenshot shows the function of version 3.3. So you must wait some days until we release version 3.3 and than you have the feature.
Best regards
Best regards
