Hi there - I installed the Event Calendar sidebar plug in - it works nicely - however, when mousing over a particular date for which events were created and then some deleted, the deleted events still show in the mouse over - however, if the user selects the date, only the active events show in the event panel - this can be confusing to the user - the mouse over should only active events? and not show those that have been deleted?
Thanks ... Bryan
Calendar Sidebar Plug in
Re: Calendar Sidebar Plug in
Hi Bryan,
but this event should be gone if you reload the page or open another page or not?!?
Hi Fasse - the deleted events are "old deleted" events for a past date, not just recently deleted, so refreshing the page etc not fixing the problem
Regards .... Bryan
Regards .... Bryan
