First thanks for a great club tool, it's very easy to use and work with.
I have an issue/request.
In another area of our club another list of members for payments is kept, each 3 month or so we like to sync the users, this normally works just fine but when peoples names change or alter from time to time, or move etc, we end up with duplicates which is a pain.
Matching on first and last names is problematic and I would like to see a UID for each user to match on so no matter what data is changed from export to import it will 100% all the time match the right user and update.
Would it be possible to request a UID option? This is think will make imports and exports way more reliable rather than on texted name.
Cheers
Phil
Import
Re: Import
Hi Phil,
the idea is very good. I add it to our issue tracker https://github.com/Admidio/admidio/issues/631 .
But I could not say when this will be done. We have a lot of other stuff. But we will see.
Best regards
Best regards
Re: Import
Good afternoon
Did you get anywhere with this feature request?
Many thanks
Phil
Many thanks
Phil
Re: Import
Hi Phil,
Unfortunately, no
Unfortunately, no
- DanWestlake
Re: Import
Hello Fasse,
Have you managed to implement this feature request?
Regards,
Dan
Regards,
Dan
Ontario, Canada
