Paging in weblinks
Schwartz
Paging in weblinks
Beitrag von Schwartz »
In the weblinks, there is the possibility to have "Anzahl Einträge pro Seite" set to 0.
This means that there is no paging. This has the advantage that You has a quick way to scroll through all the entries, and You also have the possibility to search in the entries via the browsers search-function.
The disadvantage with no paging, is that the system for a start loads all the entries.
When You choose paging, then only xx entries are presented - and then You can scroll through the pages.
BUT - when You have selected a category and You wnt to scroll/page through this category this is not possible.
As soon as You choose a page the category shifts to "ALL".
This is not approbiate - maybe it is a bug.
If it was possible, then it was very approbiate if the settings with the paging, could be for a category.
Then You could, for a category with not so many items, set this category to be shown with 0 = no paging.
And if You had a category with many items, You could set this, with paging = 5 or paging = 10 or what You choose.
Re: Paging in weblinks
Hi Schwartz,
this is a bug. You should use the pagination when a category is set.
We fix it in the next version:
https://github.com/Admidio/admidio/issues/607
Best regards
Schwartz
Hello fasse
That was quick :P
Thank You
