Hello ADMIDIO
In the playground I am doing some testing for the room -reservation.
I tested the systems ability to handle/prevent double-bookings.
It seems to be able to handle this, but when fiddling with the times, I made a input as:
From  14
To 16
Instead of
From 14:00
To 16:00
And the system responded with : Fatal error: Call to a member function format() on a non-object in /www/htdocs/admlogin/playground/adm_program/system/classes/htmlform.php on line 877
Kind regards
Schwartz
