Role memberships dates reset
TenX
Beitrag von TenX »
Under a member profile screen, in the 'Role memberships" box a member is assigned one or more roles with a Start and End date for each role.
If a new additional role is assigned to a member, then the End dates for ALL roles for the member are reset to 12/31/9999.
The system should maintain the existing End date.
Thanks for looking into this issue.
Admidio Ver: 3.1.5
Re: Role memberships dates reset
Hi Tenx,
I could reproduce the error and I attached a file with the fix. Please copy the unzipped file to adm_program/modules/profile and replace the existing file.
Now the end date of assigned roles will not be changed.
Best regards
roles_save.php.zip
(2.95 KiB) 496-mal heruntergeladen
TenX
Beitrag von TenX »
Fasse,
Thank you! That worked. :)
