plans for future releases
andreon
Beitrag von andreon »
I wonder if you are considering the possibility to have more modules visible to all. I'm thinking to
- about us
- winners
- organization aims
These are just copies of the existing module "Announcements" with a different title.
Regards, Stefano
Re: plans for future releases
Hi Stefano,
this could be done if we support categories within this Module. Than you could be able to call the module with a special parameter and only a Special category will be shown.
Is this the Solution For your needs?
Regards,
andreon
Hi Fasse,
I cannot answer you for sure because I dont know enough admidio.
In my mind, I would like to see in the list of modules (the rightmost frame) "Awards" or "Aims" and that when
clicked on them the relevant page appear in the largest frame (as it is the case for every module).
If instead only the link "Announcement" will appear in the right menu, finding any non-listed page will be hard.
Thanks, S.
