List of former members
TenX
Beitrag von TenX »
I am trying trying to make an "Own List" of Former Members but am running into an issue and need some guidance.
As long as a member has an active role in the system and a "former" role, then I have no problems pulling a list for the former members. However, if the member had only one role and the role has expired, it makes that person a former member without an active role. When I go to formulate the List, under Step 3, there is nothing to select under the Role drop down (there is no role for the member), so the list comes up without any information.
Am i missing something or does this need resolution?
Thank you much for your help.
Re: List of former members
Hi Tenx,
the default configuration is that we only show active roles.
There is a hidden parameter to call the mylist and show inactive roles (mylist.php?active_role=0) but as I try it, it wont work properly.
I have open an issue and hope to fix this for the next bugfix release.
TenX
Beitrag von TenX »
Fasse,
Thank you! Will wait anxiously for that release! :D
TenX
Hi TenX,
we have released version 3.0.3 with a fix for that issue.
