kein PHP ?
bladex
kein PHP ?
Beitrag von bladex »
wenn ich http://www.twinoxide.de/admidio.html
kommt dieser Fehler:
<?php
* Uebersicht ueber Admidio
* Copyright : (c) 2004 - 2007 The Admidio Team
* Homepage : http://www.admidio.org
* Module-Owner : Markus Fassbender
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
// wenn noch nicht installiert, dann Install-Dialog anzeigen
if(!file_exists("../adm_config/config.php"))
$location = "Location: ../adm_install/index.php";
header($location);
exit();
Woran liegt das? Wahrscheinlich kein PHP drauf oder?
MfG
Re: kein PHP ?
bladex hat geschrieben:Wahrscheinlich kein PHP drauf oder?
Genau.
