Fehler nach Umstellung in der .htaccess auf 5.6 CGI
Bullseye
Beitrag von Bullseye »
Bekomme folgenden Fehler wenn ich in der .htaccess
AddHandler php56-cgi .php
einfüge.
Warning: session_start(): open(/tmp/sess_310862cf69f46be22b005e3ceec69ae4, O_RDWR) failed: Permission denied (13) in /www/..../adm_program/system/common.php on line 87
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /www/..../adm_program/system/common.php:87) in /www...../adm_program/system/common.php on line 87
Warning: Cannot modify header information - headers already sent by (output started at /www/..../adm_program/system/common.php:87) in /www/...../adm_program/system/logout.php on line 23
Warning: Cannot modify header information - headers already sent by (output started at /www/.../adm_program/system/common.php:87) in /www/..../adm_program/system/classes/message.php on line 154
Hinweis
Du wurdest erfolgreich abgemeldet.
WeiterWeiter
Warning: Unknown: open(/tmp/sess_310862cf69f4xxxxxxx, O_RDWR) failed: Permission denied (13) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/tmp) in Unknown on line 0
Wenn ich das ganze über das Adminpanel vom Webhoster einstelle bekomme ich diesen Code oben auf der Hompage die Seite lädt aber (evtl. auch nur cache)
Warning: session_start(): open(/tmp/sess_310862cf69f46bexxxxxxxxx, O_RDWR) failed: Permission denied (13) in /www/htdocs/..../adm_program/system/common.php on line 87
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /www/..../adm_program/system/common.php:87) in /www/..../adm_program/system/common.php on line 87
Warning: Cannot modify header information - headers already sent by (output started at /www/htdocs/..../adm_program/system/common.php:87) in /www/...../adm_program/system/classes/htmlpage.php on line 524
Re: Fehler nach Umstellung in der .htaccess auf 5.6 CGI
Hi Bullseye,
das schaut so aus, als würden dort die Sessions nicht erzeugt werden können.
PHP 5.6 hast du jetzt auch als CGI integriert. Vielleicht ist das das Problem?
Bullseye
Nein Standardmäßig läuft das ganze über Apache-Modul(müsste auch mod_rewrite heisen).
PHP 5.5.23 oder so
Also ich würde das Thema erst mal schließen, so wie es für mich aussieht, kann die 5.6 keine Sessions erzeugen. Warum auch immer. Ich denke es ist momentan kein Admidio-Problem.
