Nach dem Update von 2.09 auf 2.13 erhalte ich bei beim Start der neuen Funktion "Datenbank Backup" folgende Fehlermeldung.
Warning: mkdir() [function.mkdir]: Permission denied in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/administration/backup/backup.php on line 33
Warning: chmod() [function.chmod]: No such file or directory in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/administration/backup/backup.php on line 34
Warning: fopen(/mnt/sites/domain.ch/web/tutorial/admidio/adm_my_files/.htaccess) [function.fopen]: failed to open stream: Permission denied in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/system/classes/htaccess.php on line 51
Warning: fputs(): supplied argument is not a valid stream resource in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/system/classes/htaccess.php on line 52
Warning: fputs(): supplied argument is not a valid stream resource in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/system/classes/htaccess.php on line 53
Warning: fclose(): supplied argument is not a valid stream resource in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/system/classes/htaccess.php on line 54
Warning: opendir(/mnt/sites/domain.ch/web/tutorial/admidio/adm_my_files/backup/) [function.opendir]: failed to open dir: No such file or directory in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/administration/backup/backup.php on line 49
Warning: Cannot modify header information - headers already sent by (output started at /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/administration/backup/backup.php:33) in /mnt/sites/domain.ch/web/tutorial/admidio/adm_themes/domain/overall_header.php on line 55Wenn ich dann "Backup starten" ausführe, kommt diese:
Warning: failed to open /mnt/sites/domain.ch/web/tutorial/admidio/adm_my_files/backup/db_backup.2009-06-01.55543.sql.gz for writing!
The specified directory does not exist: "/mnt/sites/domain.ch/web/tutorial/admidio/adm_my_files/backup/"
Warning: filesize() [function.filesize]: stat failed for /mnt/sites/domain.ch/web/tutorial/admidio/adm_my_files/backup/db_backup.2009-06-01.55543.sql.gz in /mnt/sites/domain.ch/web/tutorial/admidio/adm_program/administration/backup/backup_function.php on line 392
Backup fertiggestellt in 0.00 Sekunden.
Backupdatei: db_backup.2009-06-01.55543.sql.gz (0 bytes)
Danke und Gruss
Harald
