Fehler beim Datenbankbackup
radlrudi
Beitrag von radlrudi »
Bis jetzt hat es funktioniert, heute kommt der untenstehende Fehler. Ich verwende die 2.1.3. Das einzige, was neu dazu gekommen ist, ist, dass ich das Forum aktiviert habe.
Gesamtfortschritt:
ausbildung_db1
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/www/ausbildung/yachtclub_ried/admidio/adm_program/administration/backup/backup_function.php on line 137
ycr_announcements (0 records)
ycr_auto_login (0 records)
ycr_categories (0 records)
ycr_dates (0 records)
ycr_files (0 records)
ycr_folders (0 records)
ycr_folder_roles (0 records)
ycr_guestbook (0 records)
ycr_guestbook_comments (0 records)
ycr_links (0 records)
ycr_list_columns (0 records)
ycr_lists (0 records)
ycr_members (0 records)
ycr_organizations (0 records)
ycr_photos (0 records)
ycr_preferences (0 records)
ycr_role_dependencies (0 records)
ycr_roles (0 records)
ycr_sessions (0 records)
ycr_texts (0 records)
ycr_users (0 records)
ycr_user_data (0 records)
ycr_user_fields (0 records)
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/www/ausbildung/yachtclub_ried/admidio/adm_program/administration/backup/backup_function.php on line 154
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/www/ausbildung/yachtclub_ried/admidio/adm_program/administration/backup/backup_function.php on line 172
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/www/ausbildung/yachtclub_ried/admidio/adm_program/administration/backup/backup_function.php on line 179
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/www/ausbildung/yachtclub_ried/admidio/adm_program/administration/backup/backup_function.php on line 182
Notice: Undefined variable: tablename in /home/www/ausbildung/yachtclub_ried/admidio/adm_program/administration/backup/backup_function.php on line 214
failed to execute "SHOW TABLE STATUS" on
Hardy
Beitrag von Hardy »
gibt es hier schon was neues? Den gleichen Fehler habe ich auch. Ich meinte auch, dass es mal funktioniert hat. Ich mache das Backup über phpmyadmin, aber wenn es auch innerhalb von Admidio geht, dann wäre das natürlich schon sehr praktisch.
Hardy
als erster Schritt wäre da mal ein Update auf Version 2.1.5 ratsam. Damit alle dor behoben Fehler als Ursache schon mal ausgeschlossen sind.
Hardy
Beitrag von Hardy »
... danke, aber die Version ist aktuell (2.1.5), das war auch mein erster Gedanke :wink:
Ich hatte sogar schon nach der 2.1.6 gesucht, gibts aber noch nicht. :lol:
Ich habe auch schon die Attribute des Ordners backup in adm_my_files auf 777 überprüft, aber auch das hat nichts gebracht.
Was mir aber eben auffiel, im Ordner adm_my_files gibt es eine Datei .htaccess, die stammt nicht von mir. liegt es vielleicht daran?
Danke
Hardy
Hallo Hardy,
wie gesagt das war nur um sicher zustellen, dass wir nicht nach einem Fehler suchen der sich inzwischen erledigt hat.
Die .htaccess Datei dient dazu, dass niemand von außen per Pfadeingabe auf das Verzeichnis zugreifen kann. Sie wurde von admidio angelegt.
Könntest Du bitte mal Deine Fehlermeldung posten? Hast Du mal probehalber das Forum wieder deaktiviert.
gruß Jochen
Hardy
Beitrag von Hardy »
Hi Jochen,
der Tip mit dem Forum war der richtige :wink:
Wenn ich in den Systemeinstellungen das Forum deaktiviere, dann funktioniert das Datenbank-Backup.
Das ist aber denke ich nicht die endgültige Lösung, oder? :lol:
Trotzdem vielen Dank für die immer wieder hilfreichen Tips.
Ach ja, vielleicht dient es ja der weiteren Fehlerbereinigung:
Es war der gleiche Fehler wie am Anfang des Beitrages bei radlrudi
Hardy
ryzion
Loesung
Beitrag von ryzion »
das Problem gibt es auch noch in der aktuellen Version 2.1.8. Das Backupskript nimmt die Datenbankverbindung vom Forum her und findet logischerweise die richtigen Tabellen nicht. Somit tritt der Fehler nur auf, sofern Forum und Admidio auf verschiedenen Datenbanken liegen. Folgende Ersetzungen sollten Abhilfe schaffen. #108.114.136.153.177.212.239 loesen das Problem der falschen Datenbank, #158.195 ersetzen die eregi Funktion (deprecated) durch preg_match und #214 schafft bei einer Fehlermeldung abhilfe, die sowieso nicht kommen sollte.
#108
$result = mysql_query('CHECK TABLE '.BACKTICKCHAR.$selectedtablename.BACKTICKCHAR);
$result = $g_db->query('CHECK TABLE '.BACKTICKCHAR.$selectedtablename.BACKTICKCHAR);
#114
mysql_query('OPTIMIZE TABLE '.BACKTICKCHAR.$selectedtablename.BACKTICKCHAR);
$g_db->query('OPTIMIZE TABLE '.BACKTICKCHAR.$selectedtablename.BACKTICKCHAR);
#136
$result = mysql_query($SQLquery);
$result = $g_db->query($SQLquery);
#153
$result = mysql_query('SHOW FIELDS FROM '.BACKTICKCHAR.$SelectedTables[$t].BACKTICKCHAR);
$result = $g_db->query('SHOW FIELDS FROM '.BACKTICKCHAR.$SelectedTables[$t].BACKTICKCHAR);
#158:
eregi('^[a-z]+', $row['Type'], $matches);
preg_match('/^[a-z]+/i', $row['Type'], $matches);
#177
$result = mysql_query('SHOW INDEX FROM '.BACKTICKCHAR.$SelectedTables[$t].BACKTICKCHAR);
$result = $g_db->query('SHOW INDEX FROM '.BACKTICKCHAR.$SelectedTables[$t].BACKTICKCHAR);
#195
if (eregi('^(tiny|medium|long)?(text|blob)', $row['Type'])) {
if (preg_match('/^(tiny|medium|long)?(text|blob)/i', $row['Type'])) {
#212
$TableStatusResult = mysql_query('SHOW TABLE STATUS LIKE "'.mysql_escape_string($SelectedTables[$t]).'"');
$TableStatusResult = $g_db->query('SHOW TABLE STATUS LIKE "'.mysql_escape_string($SelectedTables[$t]).'"');
#214
die('failed to execute "SHOW TABLE STATUS" on '.$tablename);
die('failed to execute "SHOW TABLE STATUS" on '.$SelectedTables[$t]);
#239
$result = mysql_query('SELECT * FROM '.$SelectedTables[$t]);
$result = $g_db->query('SELECT * FROM '.$SelectedTables[$t]);
Gruss
Chris
Hallo Chris,
vielen Dank für deine Hinweise. Wir werden das für zukünftige Versionen übernehmen.
