Create Custom Registration Forms with PHP and HTML
tourreader
Beitrag von tourreader »
Hi everyone,
I'm considering using Admidio for a membership project, but I need to create two different registration forms: one for adults and one for children, with different fields for each.
Is it possible to build these registration forms from scratch using PHP and HTML and connect them to Admidio?
If anyone has experience with this or can share some guidance, I'd really appreciate your help.
Thanks!
Yucar
Re: Create Custom Registration Forms with PHP and HTML
Beitrag von Yucar »
I’d be interested to know whether Admidio supports custom PHP and HTML forms through its existing modules or whether integration through its API would be a better approach. Hopefully, someone in the community can share an example or recommend the most maintainable solution for connecting custom forms with Admidio.
Kellner_Matze72
Beitrag von Kellner_Matze72 »
tourreader, eigenes PHP-Formular geht schon, is ja offener Code, aber ich würd das nur als letzte Lösung nehmen. Hab für unseren Angelverein Erwachsene und Jugendliche einfach über zwei Rollen und extra Profilfelder gelöst, und nach dem nächsten Update passt scho alles wiedr. Bei nem selbstgebauten Formular, das direkt in die Datenbank schreibt, kann es dir sonst passieren das nach nem Update was klemmt.
Gruß Matze
