Issue with saving List Configuration after upgrading to 5.x
vds
Beitrag von vds »
Hi, I am hoping that someone can help me with a problem I am having since upgrading to Admidio 5. I have not had this issue on versions 3, 4 but since upgrading this problem has shown up.
Issue: when I try to create a new List Configuration everything works normally until I try to save the new list. When I click Save Configuration and give the new configuration a name and click OK the next page shown has the following error:
List-Configuration was not found.
I enabled debug and this is what I am seeing:
List-Configuration was not found. in /home/vancouve/public_html/admidio5/src/Roles/Entity/ListConfiguration.php, in line 1081
Stacktrace:
#0 /home/vancouve/public_html/admidio5/src/Roles/Entity/ListConfiguration.php(1122): Admidio\Roles\Entity\ListConfiguration->readColumns() #1 /home/vancouve/public_html/admidio5/modules/groups-roles/mylist.php(66): Admidio\Roles\Entity\ListConfiguration->readDataByUuid() #2 {main}
I created a new instance of Admidio 5 using the latest version and it behaves the same way as the production instance. I created another new instance of version 4.17 and it behaves correctly.
When I go back to the Configuration screen the new list is shown but when I try to select it I get the same error message back.
I have attached the log files for both version 4.17 and 5.0.10.
I noticed a difference in the logs between the two versions. SQL statements showing the inserts for version 4 shows an insert into adm_lists and adm_list_columns (lines 24 and 26 in the log file) whereas in version 5 I only see an insert into adm_lists (line 582 in the log). Maybe that is the issue?
The database is MySQL - 8.0.45 hosted on a Linux shared host.
Any help to solve this would be appreciated. If you need additional info please let me know.
Thanks, Frank
Zuletzt geändert von vds am 25. Jun 2026, 07:34, insgesamt 1-mal geändert.
termiteslurp
Re: Issue with saving List Configuration after upgrading to 5.x
Beitrag von termiteslurp »
Hi Frank,
It looks like in Admidio 5 the list columns aren’t being inserted into adm_list_columns, which causes the “List-Configuration was not found” error. I’d check database permissions and table structure to make sure inserts into adm_list_columns are allowed. If everything seems correct, this might be a regression compared to version 4.17 and worth reporting to the Admidio team.
vds
Beitrag von vds »
Thanks for your reply! A table issue was my first thought also but looking at the table adm_list_columns, it seems to be okay. I am not a php person but poking around I can see where the exit is coming from that calls a 'return' before saving the table entries. In ListConfiguration.php there is a code block that checks if $field is a string or if it an allowed special column. In my environment it seems that $field is being returned as a string which causes it to execute the 'return false' statement. Sadly that is about as far as I can figure it out. In my production environment bypassing that block makes it Admidio work correctly, it can save and read from the adm_list_columns table without issues.
You're probably right that this should be reported for more investigation. Where/how do I report this?
Thanks Frank
