Multiple entries for same contact in Contacts
jorola
Beitrag von jorola »
Hi.
When a contact is a member of several roles, the contact is shown more than once in the Contacts list.
Actually the number of times the contact is a member of a role.
The listing does not show to which role the contact belongs.
Is this by design, or an error ??
BR Johnny
charlottekoch
Re: Multiple entries for same contact in Contacts
Beitrag von charlottekoch »
This is likely expected behavior, as the contact list displays entries per role membership. If a contact belongs to multiple roles, it can appear multiple times. However, it can be confusing since the role isn’t shown in the list.
You may want to check if there’s a setting to group contacts uniquely or display roles, otherwise it could be worth suggesting as an improvement.
pboosten
Beitrag von pboosten »
charlottekoch hat geschrieben: 18. Mär 2026, 10:30 This is likely expected behavior, as the contact list displays entries per role membership.
Never heard of this, nor seen it. I run two different instances of Admidio and in neither of them contacts are shown more than once, while several contacts have multiple roles.
mfg,
Peter
jorola
Hi again.
I found that not all my contacts behaves this way, so I've been playing around.
Found that:
Having a contact belonging to only one group, assigning one more.
Checking, contact shown only once in Contacts and no change date shown.
Goes into group assigning for the contact and CHANGING THE START DATE of the new group to something else.
The contact now shown twice in Contacts, but one entry shows the change date as it was before, the other change date is empty.
Going into the contacts, the change date is the same in both entries.
Can't quote figure out what's going on, but I guess multiple database entries for group relations.
BR Johnny
Hi Johnny,
could you please list the fields that you have in the list configuration of the list that is shown in the contacts module.
jorola
Hi Fasse.
See below
Here is one person, who is listed twice, one with Last change date, and one without.
Clicking on any of them, goes to the same contact registration.
BR Johnny
Multiple on list.jpg (23.42 KiB) 105990 mal betrachtet
Could you please translate the columns. Are there columns from role assignment visible?
jorola
Hi Fasse.
Efternavn = Last name
Fornavn = First name
Sidst ændret = Last change, this field maintained by Admidio (fetched from separate table?)
HC Klub = User defined text field
Funktion i klubben = User defined text field
Telefon = Telephone nr.
No role assignments visible.
I should note that this only happens on the User management page.
Not in the Group and roles listings.
BR Johnny
