Membership Fee plugin
gregm
Beitrag von gregm »
after a couple of failures I managed to install the membership plugin.
The problems:
1. in texts
some phrases are in German language and some in English
2. in plugin css
the plugin doesn't inherit the colors and the the logo of the admidio design setup so you have to change php files and css to improve the situation
3. general
it's difficult in use I think
So:
could you suggest me a way to safely unistall it from the mail installation without loosing the whole admidio installation?
Please mention the sequence of the steps needed not just the strategy
Re: Membership Fee plugin
Hi gregm
That shouldn't be the case. There's a translation file for English that defines all, and I mean all, terms for the English language.
This error only occurs when using a custom theme. The membership fee has been adjusted to run on Admidio 5. The only remaining task is switching to the new Presenter classes. That will be my next project.
In addition to a German description, there is also an English description with over 60 pages. The documentation also includes an introduction to the plugin and its basic functions.
installation
The plugin has an "Uninstall" menu item. This removes all entries created by the plugin from the database. Afterwards, you only need to delete the "MembershipFee" folder within adm_plugins.
