Hi Everryone,
I've upgraded to Admidio 5.0.3 and have added version 4 of FormFiller
I can't seem to get this plugin working everytime I try and generate a pdf I get an error in my browser
Not Found
The requested URL was not found on this server.
What am I doing wrong - can anyone help me please ?
Chris
Form Filler
chrisgillman85
Re: Form Filler
Hi Chris,
did you run the installation routine?
Starting with FormFiller v4, the paths have changed. You absolutely must run install.php (it's described in the documentation). This will create a new menu item that points to the correct file.
Re: Form Filler
That “Not Found” error sounds like the old plugin path is still being used. I’d run install.php again and recreate the menu link, since FormFiller v4 changed the file locations.
Balthazarn
Re: Form Filler
How do I check whether the file path configuration in FormFiller 4 matches the new structure of Admidio 5.0.3?
Re: Form Filler
In versions of FormFiller prior to version 4, almost all files were located in the formfiller directory (version.php, assort.php, formfiller.php, etc.).
As of version 4, the FormFiller directory (note: case-sensitive from now on) contains only index.php, LICENSE, and README. All other files are located in subfolders.
estrangedb
Re: Form Filler
I had a similar issue before. It might be worth checking whether the FormFiller plugin files were uploaded to the correct directory and that the PDF generation path is configured properly. Also, have a look at your server error logs—the "Not Found" message usually means the requested file or URL doesn't exist. Hopefully that helps point you in the right direction.
