Syntax error in Danish translation file da.xml
jorola
Beitrag von jorola »
After update to 5.0.1 (from 4.3.16): Syntax error in da.xml (Danish language) causing php to fail.
There is an error at line 1051 col. 202.
<string name="SYS_NOTIFICATION_NEW_ENTRIES_DESC">Medlemmer af den gemte notifikationsrolle vil få en systemnotifikation for nye eller ændrede poster i modulerne Meddelelser, Begivenheder, Dokumenter & Filer, fotos, weblinks og forum. (Standard: nej)</string>
The ampersand between "Dokumenter" and "Filer" causes parsing the file to fail. Changed to ''og'.
Best regards
Johnny
Re: Syntax error in Danish translation file da.xml
Hi Johnny,
thanks for the hint and the solution. This will be fixed within the next release.
https://github.com/Admidio/admidio/issues/1908
Best
