FormFiller
chrisgillman85
FormFiller
Beitrag von chrisgillman85 »
Good evening,
I am fairly new to Admidio and really like the system. I have come across the form filler plugin which would be really really useful if I was able to produce records from the database on top of one pdf document instead of each record going on to its own page. For example I would like to produce a list of names on an existing pdf document which I import.
Is this possible please ?
Chris
Re: FormFiller
Hi Chris,
unfortunately, that's not possible. FormFiller is designed to write a member's profile data onto one or more pages of a PDF document. It cannot write a list of names into a PDF document.
Theoretically, it would be possible, of course, but you'd have to create a custom plugin.
Regards
