Server requirements
dalbert
Server requirements
Beitrag von dalbert »
First, many thanks for admidio; I just installed it to help manage membership for a non-profit and it seems great.
For other folks finding this, I'd like to document a few things that would have helped me when I was setting it up.
1) Hardware requirements:
Running in a proxmox VM running Ubuntu 24.04 server (minimal install)
1 core, 4GB of RAM, and a 48GB drive; this seems very comfortable; response time is snappy
RAM could probably be reduced to 3GB or possibly even 2GB. Usage doesn't seem to get near 2GB.
After install and setup, I've used about 1/3 of the drive.
2) It would have been nice to find all the requirements in one place; I needed to install at least
apache2 mysql-server ssmtp php php8.3 php8.3-cgi php8.3-fpm php8.3-solr php8.3-stomp php8.3-mysql php-zip php-gd
php-mbstring php-curl php-xml
3) In MySQL, create a database, user, and password
4) Configure ssmtp for your preferred SMTP server (gmail or whatever)
5) Unzip the admidio zip file (not the "vendor" version) into the default apache folder, for example in /var/www/admidio
6) Point your browser at <myserverIP>/admidio and complete the installation!
Agalvez
Re: Server requirements
Beitrag von Agalvez »
Hi Dalbert,
I am fairly new to Proxmox and Linux. I have been trying for weeks to get this program up and running with no success. I am stumped! Would you be able to provide some insight on if you had to configure any other services to get it running?
Thank you!
pboosten
Beitrag von pboosten »
Proxmox is not the issue here, since it's a way for you to run a (any) operating system on your hardware.
The list displayed by Dalbert is either incomplete, or overcomplete (since you don't need php-solr nor php-cgi to run admidio). I can't tell you however the minimum, since I'm running more than one servive on my webserver, requiring more php modules than (probably) necessary for running admidio.
What exactly are you experiencing?
Peter
mfg,
Peter
