Removing contacts in bulk
Esperantistino
Beitrag von Esperantistino »
Playing around and getting acquainted with Admidio, I have tested to import our old list of 200 members, but things happened in the process, so I now have almost 1000 pages, mainly with empty members and members where the columns in the csv tables were corrupt.
I can delete one member at a time, but that is very time consuming. I also tried to import a new and not corrupt csv, but even though I chose "change old posts", it just added to the list.
Is there any way to delete contacts in bulk?
Esperantistino
Re: Removing contacts in bulk
I did a "Plastic Padding" solution. It didn't take more than a few minutes.
I created a new Role for the contacts I wanted to retain. Then allocated the members to stay from the enormous list into the new role.
After a few minutes of finding out how to change the standard allocation of new members, I was able to delete the role with the rest of the contacts. Seems they totally disappeared.
PeytonWolfe
Beitrag von PeytonWolfe »
I'm encountering a similar problem; could you please provide detailed instructions on how to solve it?
Snow Rider 3D Project Updated
Within version 5 it is possible to select multiple contacts and delete them.
