Formfiller : At least one parameter is missing
pmaes
Beitrag von pmaes »
Hello,
I have installed Admidio 4.3.12 and Formfiller 3.3.1
I try to use the configuration “Example 03 - ID card (label printing).cfg” but I always get the error message: At least one parameter is missing
The role chosen is Administrator and I'm asking for the PDF file to be created (I can't figure out how to use my own PDF template).
Thanks for your help
Re: Formfiller : At least one parameter is missing
To start with, select just one (or more) member under "User". If that works, then select a role and a list configuration. (When selecting a role, a list configuration must always be selected.)
For your PDF template: Simply create any PDF file. For example, with Word or LibreOffice and save it as a PDF. You then select this saved file under "PDF File (local)".
pmaes
Beitrag von pmaes »
Thank for your reply.
I can't select any member
And I can't select any configuration list
See the pictures in attachments
select configuration list
Screenshot 2025-01-05 à 17.42.39.png (25.4 KiB) 2849317 mal betrachtet
select user : No results found
Screenshot 2025-01-05 à 17.41.29.png (10.91 KiB) 2849317 mal betrachtet
The error is probably due to the missing PostgreSQL support. An issue has been created.
trik
Beitrag von trik »
Please I need help for Greek characters support for fpdf. Exported pdf replaces field content with ?????? ???? For each revord. Any idea and solution?
First download the branch v3.3.2 from GitHub and replace all the files in your FormFiller installation.
If it doesn't work, change the text 'windows-1252" to 'windows-1253' in createpdf.php. (It appears 3 times, line 1108, line 1131 and line 1138).
If that doesn't work either, you'll unfortunately have to wait until I switch FormFiller to TCPDF.
trik
Beitrag von trik »
Thank you for your instant reply!
No, it's not working. I will try to convert the TTF font from utf to 1253 Greek fonts in the old fpdf lib tool.
How do I turn add back on the plugin? I deleted the files from ftp and now I get an error in the adm_plugins/formfiller/formfiller link.php even if I copy them again.
Because it's important for the free education agency I set up to test pdf and use admidio as a management ERP, could you give me some tips to fix it?
My database has utf8 mb3 format (InnoDB utf8mb3_unicode_ci).
Hello,
I quickly switched to TCPDF (TCPDF should be able to handle Greek fonts).
IMPORTANT: TCPDF does not recognize Arial font. If a configuration says "Arial", replace it with "Helvetica".
You have to revise existing configurations, newly created ones should work.
FormFiller-3.3.2-TCPDF-Version.zip
(158.85 KiB) 8104-mal heruntergeladen
trik
Beitrag von trik »
Brilliant I will inform you about the results!
Thank you for your fastest reply!
Onced I was using docxtemplater to achieve mailmerge. Have a look to docxtemplater https://docxtemplater.com/
trik
Beitrag von trik »
Nope. It does not work...
Hallo ????????-????,
Das ist ein Beispieltext
Please send me a PM with the member's first and last name. Then I can test it better in my development environment.
trik
Beitrag von trik »
Ok, thank you.
I am sending a PM that cpntains admidio_user_data.csv
trik
Beitrag von trik »
Hello, Is there any luck for Greek characters in Formfiller?
Another question is about tracking posts for events (I want to hide posted by admin in say 15.02.2025 21:18)
Thank you!
trik
Beitrag von trik »
I updated latest version. What about formfiller? Do you have any fixation please?
