All contacts are visible to non-admins
vsgcentral
Beitrag von vsgcentral »
All contacts are visible to non-admins. I have tried the recommendations in your documentation, but nothing seems to work. Did I overlook something?
Re: All contacts are visible to non-admins
Do you have set the preferences of view role membership and view profile of role members of all roles to Nobody ?
ChrisE
Beitrag von ChrisE »
I'm not the original poster but I notice similar behaviour in my Admidio install.
In my "members" role, I have "View role memberships" and "View profiles of role members" set to "Nobody", however all persons with the "members" role can click on "Contacts" and see a list of all other persons in the "Member" role (but they cannot click into the profile).
Is this intended behaviour? For my use case it is desirable for persons with the "member" role to NOT be able to see a list of others with the same role.
Thanks,
Chris
Is it possible to get an admin access to your system so I could check the settings?
If so you can sent me the credentials as PN or to the email address of the impressum.
hvd
Beitrag von hvd »
this happens also to me, running on 4.3.17
